DID NEW SHOWER HEAD BREAK MY SHOWER
18 Sep 2006
Lancashire
I had a Gainsborough shower 18 months old, the shower head seemed 'not right', I replaced with a new shower head, switch on, and water was dripping through the shower unit, rang plumber who said as water had got in there it was best to get a new shower.
Forked out £200 on new shower and paid plumber to fit it, but, did the new shower head cause this fault, I can't see it but plumber said new shower head had a restrictor which I should have removed to get more flow, and that this had 'blown' the shower. Is this possible?
It's possible the pressure relief, which is just a small blip of rubber had blown out.
Less than a tenner to buy from the shower doctor, to fix your old shower
yes, more than likely. tho the 'blow off' tube should terminate just below the shower casing to prevent water going back inside the unit.
as terry said, less than a tenner. you'll baulk when you see it tho, i thought boiler parts were expensive!.
the shower head is critical to the working pressure, and should be cleaned regularly to prevent the shower overheating and causing hot/cold fluctuations in the water temperature whilst showering. is this why you changed it?
on an electric shower you should replace the shower head with an 'official' replacement to prevent this 'blow off' from happening
