difference between a Worcester CDi? and Ri?
29 Jun 2006
Both heat only boilers, both sedbuk A, and both greenstar's
cdi described as 'conventional' Heat only.
only difference seems to be that CDI has fixed output and Ri has a modulating or range rated output.
(i'm looking at the plumb center price guide)
Do you mean CDi and Ri? Or have they bought out a new one?
worcester bring out different models for everything
i beleive before the greenstars they had two exact same combis but one had a user HW adjustment the other didnt! whats the point in that
I've just noticed that the Cdi's are only available as 30 or 40kw models, and Ri's dont go above 24kw odd
so they maybe the same boilers with different names because of their outputs??? :? :?
The internals of the 30 and 40kw must be different to the leser output models(Ri) thus warrenting a different model name.
Well thats my guess anyway.
I think that Worcester boilers are a tw*t to install - the electrical connections, the jig etc... compared to other manufacturers
ever have to install the SE CDI's ?
came with a big cross 'X' with two threads sticking out, and like the new ones you had to measure where to put everything a template is obviously too easy.
I've only been plumbing for 3 years and i've already noticed that Worcester wall hung boilers are a pain in the arse compared to the other stuff we install (Gloworm, Ideal,Baxi etc) for all their reputation as the dogs nads (although i read that Vaillant seem to be the top dogs at mo) Worcester are doing themselves no favours regarding ease of installation. The gas engineer in work says that they used to be easy to install (i think he said they used to use a rigid single piece jig) and the new ones are a bitch. why have they gone backwards? its totally illogical.
I loved the old cdis no horrible washers pull the boiler out and slam it back to the wall brilliant
