All, I have a Merlin Gerin distribution board in my garage.
Some 12 years ago I believe that the distribution board was set up as three phase as the then owner of my house had a small tool shop in the 5m x 10m garage. And I believe 10 years ago the three phase was reduced to one phase and 6 MCBs put in for the lights and plug sockets for the garage and ‘office’ (actually a section of the garage he set aside with a stud wall).
For details there are following circuits in use (I went into garage roof to check the cables)
A) Outside Lights, 6Amp MCB, C60HB…….Radial Circuit using 1mm2 T&E cable going to PIR and three outside lights (180W).
B) Office Lights, 6Amp MCB, C60H…….Radial Circuit using 1.5mm2 T&E cable going to 2 Florescent lights (140W).
C) Unused/NC, 20Amp MCB, C60HB…….No circuit, no cables
D) Garage Lights, 10Amp MCB, C60H…….Radial Circuit using 1.5mm2 cable T&E going to 13 Florescent lights (1000W).
E) All the Sockets, 20Amp MCB, C60HB…….Two separate Ring Circuits (one to office one to garage) using 2.5mm2 T&E cable, going to 8 Sockets in Garage and 4 sockets in Office.
I only use small power tools and the lights and not had any issues with the garage, but I wanted to know why I have “C60HB” and “C60H”. So my questions are:
1) I know what a “Type B” MCB is and I presume that this is shown by the “C60HB”, but What Type are the MCBs that say “C60H”?
2) Why are there two types of MCB in use “C60H & “C60HB””?
3) Should I get the MCBs that say “C60H” changed to be type B (C60HB) so they are all the same, or the reverse, or simply ignore as all is working?
Thanks, SFK
Thanks, SFK
