dw3101 said:Whats wrong with conventional methods?
David
Well, 7 FCUs would look, well, ugly.
One alternative I suppose is to run just one big ass ring or radial to power the lot on one circuit. The problem with that is, I have a Wylex with 60A main switch, so am limited to 30A MCBs. I know they do 40A but they are designed to NOT fit a 60A box... I know they fit if you modify them but I wouldn't be happy with that. A CU change is out of the question, I will only end up doing a full rewire if I fit that, as is a Henley block off to a separate CU for the kitchen (no isolator, don't fancy breaking the seal).
However I don't really feel happy with powering all the above off one 30A circuit, plus part of this exercise is to ensure the fridge is on a separate radial (never had problems with it being on the ring before, but there is always a first time). At the moment, the cooker is powered via the 30A cooker radial, fused down to 13A at an FCU. Other than that, it is all fitted to the same ring that powers every socket in the flat: again, no problems as yet but I think it could be improved.
The alternative is to run two circuits, and have two separate 4-way grids, but I would have to run the fridge off a shared ring. OK, I don't HAVE to, but I really am averse to doing all this and then having an FCU sitting there, glaring at me
I know that I would probably be OK running the cooker, dishwasher and washing machine all off a 30A radial, especially as the washing machine is hot fill. And again, that still brings in the problems of running the fridge radial through the same box.
Are you sure this isn't common? I have seen plenty of flats with a grid switch arrangement in the kitchen, seems a bit daft to go to the trouble of that, but not bother with a separate fridge radial.
