Different sized wires in the same wire holes
9 Apr 2010
Cheshire
When I try to secure a 1 mm wire and a 2.5 mm wire in the same hole (i.e. under the same screw in a switch), the 2.5 mm wire gets clamped while the 1 mm wire comes loose. What ways do people deal with that? Must they both be twisted together?
Also, what's the proper name for a "wire hole" in a junction box or switch or whatever else?
Why are you using two differing core sizes in the same terminal?
This is not a practise best used, you should ideally use the same core sizes.
Well they're both wires going into the load terminals on a switch (the feed is 2.5 mm). The switch was originally wired by an electrician to have 2.5 mm feed and 1 mm load. I'm now adding another load but using 2.5 mm cable.
You double over the end of the 1 mm wire, but not the 2.5 mm wire.
A 'wire hole' is more commonly known as a terminal.
Why are you using 2.5mm instead of 1.0mm, though?
and what is this switch isolating, I assume it's a two pole switch?
Advice i was given when an apprentice was that when offering both stranded and solid conductors into the same terminal. Is to put your strandeds in first and your soldis will **** in !
