I've got a single light in the garage which I want to replace with a couple of fluorescent strip lights.
Had a look last night to see how it's currently wired and I'm struggling to identify what I've got.
There are 2 x two core cables (1mm) without earthing.
One cable has 2 black cores, the other has 2 red cores.
The light switch is as per normal, two core and earth (red & black core).
So I don't know which is my switch and which is my circuit cable.
By the looks of it, this used to be a strip light, as some of the old brackets are still in place.
As far as connections go, one of the black core cables is connected to the live on the light fixture, the other black core is connected to the neutral on the light fixture.
The two red core cables (from the same two core cable) are connected to each other on a separate connector block.
I was hoping to swap out the existing light for a fluorescent strip light as well as add an additional fluorescent strip light, running from the same switch.
Apologies for the essay!
