I'm another in a long line of numpties who has failed to test where the cables are in a wall before drilling through, in order to put some spice racks up in the kitchen. It's something that both of us are diligent about (but not on this day).
We discovered our mistake when the heating/hot water control panel below where we drilled, had no display. We took this off to expose the plate and saw that there are two separate cables that feed in to it. We then identified (by gently pulling the wires and placing something in the drill hole and seeing it move) which of the cables was damaged - the power cable.
So, having read advice here and elsewhere, and speaking to an ex-spark, now B&Q assistant, we opted to do the following...
As it's on an outside wall, the cables are embedded in plaster, so we're not keen to dig it out and replace the damaged section. We found where the cable comes out in the attic and thought the best option was to replace a large section of cable by attaching the new cable to it and pulling it through. We'd then connect the new and old, undamaged cables with a junction box.
We attached the new cable and tried to pull it through in the attic, from the kitchen. It moved about one inch, and that was that. We then tried it the other way and again, it wouldn't budge any more.
I don't know if it's snagging on something, somewhere, or if it's simply a case of there not being enough room within the channel in the wall. If the latter, is there any merit in pulling through both of the cables (including the undamaged heater cable) in order to free up more room in the channel. Or, would the cable have been clipped/clamped in place (if that's the right term for those little 'r' shaped pins)? The house is around 20 years old. If those clips have been used, do we have any hope of pulling the wire through?
And advice would be welcome. I'd rather not have to contemplate making a large hole in the wall and then once the cable is repaired, then having an unsightly box or plate on the wall. The reason for putting spice racks up was to free up worktop space as our kitchen is tiny and this is the only place where they could be put up.
So, any advice that you could give on either how to get the cable to move so we can pull it up/down through the wall, or how to repair in an unsightly manner, would be appreciated.
