Sorry if this repeats a previous question.
A friend has a digistat SCR and RF1 setup. The RF1 only gives thermostat, no timer. Is it possible to buy just the stat/timer? 3RF perhaps? I gather there is a sequence to get the two to talk if they are compatible.
I note from other posts that the backplate is the same, so it should be easy to replace both if required. Just want to avoid messing around more than needed.
Thanks - Jonathan
Thanks - Jonathan
