Looking to replace a panel rad in the bathroom with a towel rad. Can work out the btu ok but unsure about the width I need. Existing pipes as they come out the wall are at 560mm centres and the distance between the valves fitted to the pipes (rad removed) is 520mm. I suspect I need a 550mm wide rad. Is that correct.
