Hi
Got a customer who has asked me to replace some light bulbs for LED ones, they are on a dimmer, the lights are 4 x GU10 50watt and 1 x MR16 Low Voltage (in a fan light).
The way I see it I need to remove the fan from the set up on its own pullcord and power.
Change the dimmer switch to a trailing dimmer switch
Change the GU10 bulbs to a Dimmable LED
Chenge the MR16 bulb to a dimmable one and change the transformer to a dimmable driver.
Is that correct?
Do the dimmable drivers wire up the same as a transformer, not something i have done before.
thanks
Is that correct?
thanks
