Hi, fitting an extractor in the en suite and at same time, would like to change the current light switch from regular 1 way to a dimmer. The extractor though was going to be wired to lighting circuit with a time over run for after lights were turned off.
Is a dimmer available that would offer a variable output for the lighting along with a fixed voltage on / off pole for the fan to be switched from?
So in summary - I'm after a dimmer that I can also use to supply a switched live for the extractor fan - in a single 1 gang unit.
I've noticed many dimmer switches have the input, the variable "load" output and a third terminal - not metered one, but is this a switched live that would work for my needs ?
