Dimmer switch
14 Sep 2005
Hello,
Need to put a dimmer switch onto existing 2-way lighting.
The switch at present is wired as follows; 2 red wires terminated into
common, one of which is live: black goes into L1. A second black wire
terminates into L2.
to wire the dimmer switch in, do the pair of red wires go into L2 and
the black strappers go into the existing terminals L1 and the
transformer terminal.
craig.
so change it over, but make sure your dimmer is suitably rated and the transfomer can be dimmed
As breezer says but also that the dimmer is capable of driving inductive loads if a wire wound tranformer.
