Dimmer switches blowing when 240v halogen bulbs fuse?
22 Dec 2006
Lancashire
I have several light fittings which take 5 of 50W GU10 halogen bulbs.
I have run the fittings with dimmer switches with more than adequate ratings (eg 750W).
Operation and dimming work absolutely fine until a halogen bulb fuses, when it burns out the dimmer switch.
The first time this happened I put it down to bad luck, but I've now burnt out three! On only one of these occasions it tripped the fuse at the consumer unit.
I can only assume that the fusing of the bulb has caused a momentary short circuit, but don't know how to avoid this.
Any ideas?
you have cheap lamps, decent ones are internaly fused for this reason
Good post, Breezer. As a matter of interest, where do you usually connect the live strapper wire on a dimmer switch? I have always used 'com' as with a rocker switch, but have just fitted a switch where the manufacturer specified L2. I haven't had a chance to check out why.
Lamp:
_______________________________________________________
Fitting/Fixture:
Bulb:
Hope that clears things up for you :lol: :)
