dimmers constantly blow
11 Nov 2003
3 yrs ago I moved into a brand new flat. There are 3 dimmer switches in the lounge, one which controls mains voltage downlighters. All 3 dimmers must have blown about 4 times since I've been here. It always happens when a bulb blows, sometimes the trip switch goes too. Today I turned on the lights, there was a flash as 2 bulbs blew and once again the dimmer failed. The builder refuses to come out any more.
I can't believe this is normal, can anyone tell me why this might be happening ?
cheap lamps, and underated cheap dimmers.
When a lamp blows it some times creates a short cicuit this draws more current than the dimmer can handle so its good bye dimmer.
The other thing is you mentioned the downlighters are mains, but what about the other lights IF they are low voltage it may be wrong / cheap transformers
the other bulbs are also mains voltage. The last time the electrician came he said it was a different make dimmer. No one else in the block has had the same problem.
