Dimmers not working - leading, trailing, TRIAC - very confused!
But, I'll stick with my traditional incandescents
So will I, dimmed incandescents give soft light, dimmed LEDs do not.
until LED technology is standardised / proved reliable / proved safe / cheap enough!
ignoring the stull made in factories without effective quality control,
LED technology in the LED element is reliable and safe and dropping in price,
the technology used to provide the controlled current through the element(s) is the weak point and will remain so until some form of standardisation in terminology is created and the industry conforms to it.
Use RGBW lamps, then you can have whatever colour you want.
Maybe but under volting a filament lamp gives a very satisifying glow which I have yet to see from any LED light source,
LED light lacks the infrared spectrum which while not "visible" does affect the eye and the brain's perception of the light
Maybe, but it's a very inefficient (aka 'expensive to run', for a given light output) approach, since the lumens/Watt drops dramatically if one significantly 'under volts' a filament lamp/bulb. The 'lumens/Watt' (i.e. lumens per £ over a given time period) is bad enough at design voltage, but it gets much worse if one reduces the (average) voltage.
Kind Regards, John
And the so called "wasted" heat is not lost. it reduces any heating bills
Electrical heating is much more expensive than say gas, so that is still a waste.
In summer of course the "wasted" heat increases the air con bills.
This link was sent to me earlier: ...
Thanks. That link appears to be to "professional-electrician.com", but I was interested to read, amongst other 'interesting' things ... "A small copper coil built into a TRIAC dimmer vibrates at different frequencies to disrupt the power reaching the lamp, controlling the light output.". Interesting concepts and 'professional' language!
Kind Regards, John
An occasional contribution. They have a feature "Caught on Camera" that reminds me of the old Photo of the month on here, featuring various botched jobs.
