Dimplex FCX24a installation
7 Jan 2010
Stirlingshire
I just bought a second hand storage heater without instructions not considering i wouldnt be able to find them online.
Having had previous storage heaters i was quite confident i would be able to set up however this one seems a little more advanced that ones iv had before.
There is a part which doesnt appear to be in the correct place and im not sure where it is to go. Its a metal rod attached to the input control, part number 4 on the page below
http://www.torreelectrics.co.uk/acatalog/Dimplex_FCX18_FCX24_Storage_heaters_spares_&_Parts.html
It looks like it is meant to fit into the metal clip at the front of the far right element connector however im not sure if its meant to be at the top or the bottom.
Is anyone here able to identify this part and explain whats its for.
Also does anyone have a pdf copy or a link for the instructions?
that would be a thermostat.. the "metal rod" is a bulb filled with gas or liquid that expands and pushes up the thin metal tube to move the lever on the control at the top..
Thanks for that. If it's a thermostat then am I right in saying it should be loose in the casing?
Also you might be able to help with the wiring. I have wired in the offpeak and the normal circuits however only the off peak seems to work. With the convector switch on there in no power to any of the convector components. Along side the offpeak and normal connectors there are also connectors marked timer, A and B, are these required for the convector and fan to work or are the for something else?
