I have not touched a storage heater for 20 years or more, and then it was only to do with the supply to them.
Suddenly this is the 4th since New year and the first time I've had to fault on one.
It didn't get hot and apart from struggling to get the cover off [and even worse getting it back on!] it didn't take long to discover the overheat cut out and reset it. After that it seemed to be working OK [clamped at 10A, same as a similar heater] except the piece of wire between the cut out and thermostat [positioned above the thermostat] was getting hot/smoking. The cheap multimeter shows it to be 2.4Ω and measures 1V across it, I assume [hope] the numerical error is due to the quality of the meter.
My question: is this link wire supposed to be a heating element above the thermostat and/or is it normal for it to be naked as it looks very vulnerable like this?
