Disabled WC panic alarms?
21 Jul 2008
Aberdeen
How does a panic alarm system in disabled toilets work? I know there are panic buttons in each wc area and perhaps a sounder in a main area, but how do you know which dis wc area is requiring help.
Is there an indicator on the panel which tells people which loo is in trouble?
depends how it was designed.
most opt for a nurse call system that is badged as disssabled.
smal local sounder goes off and an LED outside the one which had the string pulled or button pressed lights up
Is the LED display normally in the entrance areas or in, say, an office area? Presumably the sounder is in the entrance area though
as i said, depends how it was designed and how the owner wants / needs it
