Disconnecting a wire from a connector block
20 Mar 2004
I hate having to post this as it sounds so lame but, anyway...
My bathroom shaving light has a pull switch that's had its day. I want to have a go at replacing the pull switch (only cost me £1.49) but I need to take the light off the wall first. I've fallen at the first hurdle, though, as I can't shift the two small screws holding the brown and blue wires. My screwdriver seems to be small enough but just jumps out of the slot when I turn it.
Is there a knack? A special type of screwdriver? Do the screws turn the 'other way' (similar to the fan in an oven)? Once you've stopped laughing, any advice would be welcome. Thanks.
Have a close look at the screw-heads. Sometimes they're Phillips type and sometimes just straight slots. You obviously need to use the appropriate screwdriver ....... and it should be one with an unworn tip.
Screws these days are not very well made: they seems to be of very soft material. Usually a range of different screwdrivers is a useful thing to have. Anyway - if it were me - I'd cut the wires and use a new piece of choc block. Looks like there is enough wire spare. You will need strippers.
Thanks for that. The screws are 'straight slot' and my wee screwdriver is pretty old. I'll borrow a couple from a friend over the weekend and have another go.
If you have no joy undoing it you could cut the wires individually and replace the block if there is enough slack in the wires.
