Disconnecting my cooker
13 Mar 2012
Yorkshire
I need my electric cooker disconnecting when i move at the end of the month, is it safe to do it myself if i turn of the electric.
If you are completely unsure about your ability to do this work then call a professional.
If you attempt it yourself then you will need to be able to prove dead with a suitable instrument. You could turn off the power to the whole house if you have no test equipment but better to test as you can never be 100% sure.
Be certain not to leave any cables that will be live on re-energisation for you or the next occupant.
Many thanks for the reply, I think i'll play it safe and get someone else to do it who has some experience with electrics!
Just out of curiosity what is the best instrument to use to test if a wire is live or not?
Also what is the best way to leave the cable once iv'e taken the cooker away?
Thanks again
Ideally, one of these. http://www.toolstop.co.uk/martindale-vi13700-g-safety-voltage-indicator-p1571
Or a cheapo multimeter (£6)
Behind the cooker, on the wall, there should be a connection plate. Disconnect the cooker there, then there will be no live trailing wires left behind.
Also you'll need that cable to connect your cooker up at the next house!
