- Joined
- 11 Sep 2007
- Messages
- 947
- Reaction score
- 11
- Country
The lock on my rear door is a PVC type with four locking rollers - to lock or unlock the door you push up on the handle and turn the key.
Turning the key is getting very stiff and a bit 'crunchy' - I've dismantled and lubricated (with WD40) the handle and easily accessble lock sections and this has helped a fair bit, but it still doesn't feel 100% when turning the key.
So either the inner lock mechnism needs lubricating or replacing.
But how do I completely dismantle it?
I can see a metal strip all down the lock side of the door and a set of screws along the strip, but even with the screws removed it looks like the rollers would prevent the strip from being removed. How are the rollers removed?
Once the strip is removed is the lock mechanism easily removed? I'd like to lubricate it and also look for a model number.
The system is a Lockmaster.
Also, where can I find an exploded diagram of the whole mechanism and fitting?
