District Heating
28 Oct 2009
Good morning
Has any one got any details on the Metro KVM conheat(ravi) heat exchanger, its used in the flats built on the site of the the old Dell(Saints Fc), utilizing the district heating system, there is a Danfoss thermostatic valve that is leaking, any help on where to find spares would be greatly appreciated.
Is it this valve...?
http://heating.danfoss.com/PCMPDF/RAVI_VD52Q502.pdf
http://heating.danfoss.com/PCMPDF/VMT_VD52I802.pdf
This valve is included with Danfoss's UK domestic product range so should be subject to availibility amongst most UK heating suppliers.
You can check with the Danfoss UK office. Premium pricing though will likely apply if you go direct through them!
Bes supply the housings...
http://www.bes.co.uk/
Stock No's - 15757 - 15758 and 15759.
It may only be the stuffing gland leaking in which case a little tightning might cure the problem.
Yuo might find that the District Heating Operator is responsible for this valve? - it's certainly worth asking!! :wink:
