Hello guys hope u all ok
Hope u can all hlp
I have an oven and hob
Hob =5.5kw size of cable 6mm
Oven =2.3kw
Fuse = 30amp
All appliances are using the same cooker switch with a socket outlet
In the past I have had 2 hobs over heating and burning my worktop.
My question is if am to use the diversity method it will give me 22amp fuse in total for both Appliances. Which will mean the 30ampfuse is ok
But with out using the diversity method I end up with 34amp intotal or 7800w as load to the 6900w for the 30amp fuse.
(So is the diversity method a missing leading idea based on assumption or not ?)
I was thinking of putting the oven off the ring main with a spur fuse 13amp
And leave the hob on the 30amp fuse
Is this the right way to do it.
How would you guys wiring it in to avoid future over loads
Hope u can all hlp
Oven =2.3kw
Fuse = 30amp
