Hi, have posted before about this problem. I have a 28cdi worcester combi and when the CH heating is on the dhw is fine. However when the CH is not on the DHW is either cold or luke warm. May get hot for a few seconds only.
I have been told it could be diverta valve and checked it against this advice.
(Start with cold boiler. Turn hw tap on . Pin should emerge from diverter valve, 3" diameter part, on the left, pointing forwards, and push a microswitch. If it doesn't, change diaphragm.
HW should get hot, heating pipe (leftmost, 22mm) should NOT. Bet it does though. W240's seem to get diverters which don't divert properly, more than others for some reason.)That was for for a W240 but i presume it's the same? Anyway on that advice it seems fine.What other reason could be causing this kind of problem. Also asked this before but could a faulty pump cause this?
Any help would be appreciated.
ps: Softus don't need or want your help
