Diverter Valve Question - quick one!
20 Jan 2010
Manchester
Hello,
If the spindle on the diverter valve is working - as in it is correctly depressing the microswitch - does this mean the diaphragm is in working order, or could there still be an issue with it??
Daniel
If that happens at about 2.5 li/min then that will be the case.
But the manifold section may not be following the actuator !
Tony
Yes, the actautor is depressing the microswitch and water is flowing at a good rate.
Does this then mean that the valve behind the actuator isnt working? That'll mean a whole new 3-way valve then will it?
If you have a second - can you read my other post - this is related, but noone is answering!
Thankyou!
Daniel
