Divided spout bath shower mixer taps
11 Jul 2010
Hertfordshire
Does any one know where i can get a bath shower mixer with a divided spout from please?
I have just fitted a standard one but the cold water is going into the hot pipe so i cant use it.
Thanks :D
I've never known of one. I did once put kitchen a sink mixer on a bath, using a pair of reducing bushes.
Fit non return valves that will stop the problem youve got !
Someone on here said about the divided taps. Thanks for your advice.
My hot water tank is in my flat so I think that's why its happening.
Thanks again.
That was me :idea: the low water pressure from your hot water won`t be enough to open a check valve , in my opinion .
Thanks again.
Didnt know there was a post about the same problem under a different heading, if theres a big differential between the hot and cold pressures
I get a plumber in, depends on your hot water tank what head of water you have etc etc .
Thanks everyone for your advice.
I cant find any taps so i think i will have to get a plumber in.
Thanks everyone
:D Thank you for that, i will look into those taps, i was a bit worried about fitting a non return valve.
Thanks again everyone you have all been really helpful :D
