Hi There,
I am working on a friends house and we are going to install heating as it has had storage heaters in.
Can someone please confirm that this is correct for a combi system?
Run a 22mm heating flow pipe from the boiler for the 1st 3 meters then branching off with 15mm pipe to flow and return through all of your radiators then after your last radiator use 22mm pipe for the last 3 meters back to the boiler.
Do the 22mm pipes need to be done in copper?
We wer hoping to do it all in plastic pipe, obviously we would get a corgi plumber to run and connect the gas pipe.
Does this seem ok???
Many Thanks Steve
Many Thanks Steve
