Dlink WiFi adapter antenna problem
7 Aug 2014
Hello everyone, I am trying to build myself a helical style antenna and connect it to a wireless adapter. My wireless adapter is a Dlink DWA-123. Now I have taken it apart but I can't figure out which part of it is the internal antenna to which I will connect my home-build antenna. I have attached 2 pictures of each side of the PCB so I would like to ask, where should I connect my antenna cable?
Front side PCB
Back side PCB
Note: I think it might be the holes in the upper right of the first photo but I can't figure out where to connect the ground and the core wire.
Problem solved; most likely I can't and I have to use a wifi adapter with an antenna port.
