For the building inspector to signoff a project does the plasterboard have to be skimmed, or is it sufficient to just joint it, paper with lining paper and then paint ?
Using taper edged boards and jointing/filling the tapers, so skimming is not needed... unless you balls up the jointing.
Normal thickness boards 12.5mm
The project is a detached Barn conversion into a single dwelling - I'm trying to get as much info as I can in advance .... but on this question I guess I'll just have to wait until I can ask the inspector.
