Hi
I am helping out an friend with an aggressive developer next door.
The two houses have detached but joined garages. The builder (122) wants to remove their garage to make room for a side extension to the house.
The original garage walls are of 4" brick. Small integral pillars (4") are installed in the front area. Originally it would have been like the diagram below (I guess this is as standard as you can get for joined garages). Beams connect the outer walls (passing through the central wall) to support the roof. The roof is mainly of sheeting material but there is a small decorative clay tile roof at the front.
Many years ago the owner at 124 built another garage at the rear of the existing. This meant knocking down the rear wall and installing a concrete beam so that a single open space is created. So the current state is as follows
This has been the state for a lot years and it appears quite stable. Bracing is achieved due to the rear wall of 122 and the connecting beams joining the outer walls.
So the builder wants to wholly remove the garage at 122 to leave the following
The PW surveyors are happy with this and see no problems. They say that joined garages being split is a relatively common requirement and this is the standard way it is done.
I have tried to tell them that the resulting building will be unsafe as it has poor bracing. My view is that the front part of the garage will be susceptible to toppling if a side force is applied (eg high winds, materials stacked against the wall, or a vehicle knocks it).
The PW surveyors have decided to ignore my concerns for the lack of bracing. I have asked repeatedly that if the building owner takes the view that no bracing is required then a structural engineer must confirm this view. The risks to property and life are clear.
We have not quite reached deadlock at they are still completing the draft PW agreement that will formalizing their view.
Any views from this panel of experts
Am I wrong about bracing?
Is it worth taking this to arbitration if they will not either install bracing, or get an expert to support their view?
Thanks in advance
Geoff
Thanks in advance
Geoff
