- Joined
- 30 Mar 2005
- Messages
- 3
- Reaction score
- 0
- Country
In my house (75 years old) the previous owners have fastened down floorboards at right angles to the original floorboards.
Also removed a wall, so from a plan view it looks like this:
[code:1]
/ - Door |
[/code:1]
and I've laid this tongue and groove hardwood flooring that comes in strips like laminate (Westco stuff) from the top to about 1/4 of the way down.
I'm starting to notice that the wood that I've laid and glued moves up and down when you walk on it.
Also, where I've got ...'s in the diagram, the floor seems to sink and then level up again as it approaches the left (front wall) and the ***s represent where the dip is most severe (approximately 23mm).
I know I should have had it screeded, but I figured I could use different levels and thickness of underlay to sort it out.
Now I'm having problems with it moving even at the bits where it dips only narrowly (less than 5mm) I'm starting to wonder if I'm going to waste my money by finishing it, and I should bite my losses (about £150) as opposed to finishing and losing about £750 worth of wood.
[code:1]
/ - Door |
[/code:1]
