Hello.
I've recently installed under floor heating in my house that is for the kitchen only. I've worked some smart electrics and have wired it so it can run completely independently, in other words when the central heating and hot water are off it will run through just the UFH circuit through the use of some two port valves. Although this all seems to work not too bad, the slight problem I am having is as follows....
Because the boiler output is fairly high, when the UFH is calling for heat, the boiler will kick in and out often as it is cutting out on its control stat. Even though the UFH room stat is constantly calling for heat through this time. Now I am guessing that the pump is not able to pump / get the hot water away quick enough. When the boiler does fire on UFH only, it only runs for a short period as the temp of the hot water building up is so rapid.
Im lmost certain that the grundfos 25 / 60 is not pushing it around quick enough and this is te reason for the frequent cycling of the boiler. Would it be as simple as putting a higher performance pump in? If so which one could be recommended, also higher flow rate or higher head pressure?
Any help much appreciated...
Thanks.
Chris.
Thanks.
Chris.
