I will soon be laying down some T&G loft boards.
Before I do that, I need to know if the joists would need strengthening.
The joists are 120*32mm cross-sections (420mm joist centres),supporting the ceilings below, spanning approximately 10m in total. These joists presumably rest on the side wall and party wall of the property.
Perpendicular to these there are also somewhat larger beams (2 beams, dividing the loft space into 3 sections), approximately 150*50mm cross-sections. These beams also have a span of approximately 10m, resting on the front and rear brick walls of the property, and there is an internal brick wall beneath them at the approximate mid-point.
Are these sufficient to support the combined weight of the boards and items that will be stored on them?
Your feedback would be appreciated.
PS. In case it helps- The property was built in the 1930s and is an upper flat. The entire building houses 4 flats in total.
