Ive changed a double socket today and tested the 2 lives coming into the back and 1 was dead, I presumed it was a ring circuit as it has a 32a mcb.
I took off a couple of sockets to see if any wires had come loose from the back of them but everything was ok but again once I removed the 2 lives one was dead.
I checked the consumer unit as I was concerned this could be a radial circuit bearing in mind there are 24 double sockets on this circuit!
The cable is 2.5mm csa and has a 30ma rccb connected.
When I removed the cover there were 3 live conductors going into the mcb, although not to 17th edition I initially thought it could be a ring circuit and a radial going into the 1 mcb.
I removed all 3 cables and attached each one to the mcb to find out which was connected to the socket I was working on, I tested the other 2 that were not connected and they were both live also.
Initial inspection seems to suggest that each room has aprox 4 to 5 sockets and are spurred although I cannot locate where from,
But I cant figure out why all 3 cables at the mcb are live, any suggestions whats going on here??
no fused connection units anywhere
