Does thermostat in coldest area make sense?
If you put it in the hall where you often get drafts from the front door, your lounge will then get too warm. Personally, I would have it in the room i use the most, about 1500mm off the floor. Don't put it on the coffee table; that's only 4-500mm off the floor.
But somebody else might be.
You only have one thermostat so you can't have control over two different rooms. You have to have already made as sure as you can that the relative temperatures are in about the right proportion.
You can, that's what TRVs are for. If you haven't got them you can throttle some of the rads. Not as accurate but better than nothing.
See post #32
So this adjusts the relative room temperatures. Fine. But it still makes no sense to put the thermostat into a place you are not using, and hope that this makes the room you most use have the right temperature.
Plenty of installations are like that and it works fine, for the reasons I and others have tried to explain.
You're not hoping if you have TRVs or have balanced the system by throttling.
A properly designed system doesn't hope for anything. A TRV set up properly will stop any room overheating.
But the OP doesn't have it in his hall anyway.
