Does this tool exist?
8 Jul 2008
Derbyshire
I need a tool which basically acts like a kitchen peeler but with a bit more workshop heft.
Is there a wood work tool that works like this?
I need to basically score/peel sections out of insulation to make some channels in it. So rather than a push action like a planer or a chisel. I need something you can dig in and pull to basically peel a channel out of the insulation.
Any ideas?
Hmm,
I was thinking more along the lines of a lemon rind peeler thing. Something long that can be pulled back with one hand and will peel out a channel. Rather something that shaves the whole top surface.
Like a reverse chisel, if one existed.
The old time router plane is possibly what you mean - but I don't think it will work too well on slab insulation.
John :)
What are you trying to achieve ?
I saw someone "drill" a cable route through a SIPS panel by heating a ball bearing to red hot and dropping it on the insulation where it sank through and left a perfect hole.
Maybe a hot wire would do what you need?
Cut a slot out of a length of steel tube (something like an old mop shaft, curtain pole, etc), and pull that through your insulation?
Just run a sharp knife down either side of the channel required, did that for all my power cable behind insulated plasterboard.No special tool needed.
dishman, good evening
Have a look at "Woodworking microplanes?
A lot like a Kitchen microplane the type you shave hard cheese with.
Having used them to form curves Etc in hardwoods they are a quantum leap better than a rasp
Ken
Box scraper (#70). Kunz still make them in Germany (try Dieter Schmid - Fine Tools)
