dome outdoor camera ptz install help
1 Jun 2016
Ireland
Hi can anyone help me with what wires should go where?
18cmp01-00 360vision dome
289476_1.jpgp
I've hooked up 24v but still got these connections above to hook up but not sure where to start?
DATA+
DATA-
SCR
VID(+)
SCR (-)
Is a document I found online but again still not understanding it unfortunately.
Image of the unit itself.
Any replies much appreciated! :D
Alright thanks for the reply I'll go down and try this in not long.
If I've got this right put a wire going from scr- and going to scr on the camera itself?
Then a cable from vid+ into a bnc connection into dvr?
Many thanks again Handymanjo!
What cable are you going to connect the camera to the dvr with ?
What model is hikvision dvr ?
Does it have rs485 connection ?
I've got this cable
And I've also got another one like this but it is a cable coated in plastic surrounded by meshy cable?
The DVR is Hikvision I'm not 100% of the model but it is 16channel and has a dvd drive on the front I'll find out soon when I go down.
HikVision ds-721hvi-st/rw
I probably have taken your reply wrongly.
I've got inner wire onto vid+ and outer mesh wire onto scr
And scr - going to scr?
nope
camera vid+ ---> bnc cable middle wire
camera scr -----> bnc cable outer wire
scr - -----? scr
camera --> bnc --> dvr channel 1
Could I just be doing something wrong? The system was fully functional and there is still footage on it from last week, the seller who is a friend of a friend just upgraded their system and had a company come in and take the old stuff out and upgrade to newer stuff.
I've got the hikvision dvr, 360vision dome camera, 360vision keyboard and 360vision matrix - but these last two look brand new and they said they aren't sure they ever were used.
I just didn't get any cabling at all which is pretty unhelpful - I'll continue to hunt to see if I can make it function the rest of the cameras a mix of indoor and outdoor all function perfectly, shame I just can't get my head round the wiring required for the camera dome.
Then again the wiring required for using the keyboard and matrix is even more confusing so I think I'll leave those way past getting this dome working.
On the little board there are those five named connections but on the other side there is six coming from the camera and going down to five
red, black
blue, yellow
black, white
I've shot an email to 360vision doubting they'll even reply however.
Again thanks for the help so far :) you've made it a lot clearer than I had it at the start.
Do you have a multimeter, to confirm you have 24vac power present? You should hear the fans etc.
Remove link from scr to scr-
For picture:
Put the center pin of the coax to vid+
Put the sheild/ braised to scr-
How's have you terminated to coax at the dvr? Post a pic
For movement/ telemetry:
Take a cat5e/ twisted pair from data pos and neg to the 485 terminal of the dvr
You may have killed it ! Look at Dantech on eBay .... There's a 24ac one on for 5.99 never had any issues with Dantech power supplies
