Hi
(edit. i have read up part p several times now, along with various other info's, i get the impression anything low voltage / video is not covered in anyway & i am freely able to run whatever in terms of data, comms & video, although as soon as i touch mains in anyway i must be able to self certificate? or have someone who is do it? is that right? can someone please confirm it? also there is nothing on running extension leads to different rooms, or the number of plugs which can run from one UPS if the total load doesnt exceed the total capacity of the unit) also there is nothing i have found on any restrictions on how these cables can be run.
I would like to ask someone certified / qualified (which i am not..yet) several questions below, these are common installations i perform & make up "smart home" type installations.
do the following need to be done by an electrician or someone certified or be certified upon there completion? am i doing anything wrong by doing them? or can they be done by anyone? if they need to be done by a sparky / self certified person, can anyone do them & then ask a sparky to certify the installation?
these are all from a central point, for example loft or upstairs boiler cupboard. The boiler manufacturer has stated the boiler runs cool & is externally flued, with over 1ft of space between them they have stated there is no concern to the boiler. Also it does not block access to the boiler for maintenance.
a standard install would include
cctv cabling (12vdc power, 24vac power & video (shotgun cable) & 12v control cable for ptz if required)
telephone master socket relocation, telephone extension point installation, satellite cabling from dish to wall points via distribution amp, (existing dish)
TV ariel distribution systems with 12v sky passthrough
cat5 data network cabling providing wall mounted network points usually in plasterboard pattresses
installation of a knee high metal rack mount cabinet to house equipment
installation of the following items - adsl modem, network hub, patch panel, battery backup UPS, cctv recorder, ariel amplifier, desktop pc.
installation of wall mounted multi function faceplates in bedrooms, lounge, kitchen / diner (cables run inside partition wall) for tv, satellite, phone, network etc.
as a seperate question as i feel this may have seperate answers
installation of loft lighting, taken from existing upstairs lighting circuit
installation of this equipment in a boiler cupboard - any regs against?
installation of a spur in the boiler cupboard, can it be taken from the heating circuit if the heating circuit has its own trip? can i take it from another room? can an extension lead be run through the attic into the boiler cupboard if it is not hard wired & still plugs in?
there are usually some 10+ mains plugs, although these run from a UPS, so only 1 UPS plugged into the spur / extension lead (depending on install)
do the video / low voltage cabling runs have to be run in trunking / be clipped to a joist or follow a specific path through the house / loft space to meet any regs?
Thanks in advance,
josh1e
Thanks in advance,
josh1e
