My doorbell, which is wired (2 wires) is acting up.
The bell push works most of the time but not all the time.
There are no screws on the bell push cover, so how do I remove it without damage?
Its worn out, they are so cheap get a new one.
Without a picture not easy to tell you how to remove, the push itself probably has lugs that spring out, try to pull it out gently, then with a flat knife push in the tab, there will be one each side.
"No man is an island, entire of itself; every man is a piece of the continent, a part of the main. If a clod be washed away by the sea, Europe is the less, as well as if a promontory were, as well as if a manor of thy friend's or of thine own were: any man's death diminishes me, because I am involved in mankind, and therefore never send to know for whom the bells tolls; it tolls for thee."
