- Joined
- 10 Aug 2015
- Messages
- 45
- Reaction score
- 0
- Country
I have an outbuilding with a pair of large doors, both like the picture below. They’ve started to sag towards the centre, which might not be a surprise given their size and the lack of bracing.
I’m not sure what I can do to fix it so I was hoping for some advice.
I see 2 problems; getting them square and then keeping them that way. To square them up I was considering mounting some eye bolts through in the top right/bottom left corners and putting a ratchet strap on there. I could then dowel through the tenons to try and pin them (since properly re gluing them isn’t really an option).
I guess the door also needs diagonal bracing? I’m not sure if the centre member is mortised in to the top and bottom or just there to support the cladding, but I see 2 options: a 2 piece brace birds mouthed in to the centre vertical, or cut a gap through that centre member and run a single long brace through the middle.
The depth of the door would allow for timber about 30mm thick to be used.
Any thoughts gratefully received, along with any alternative solutions. I am not exactly a master carpenter so whatever option is most likely to work with the best margin of error is probably best..
