Dorgard closer issue
7 Mar 2007
Cambridge
Strange Dorgard Battery Issues – Any Advice Appreciated
I’m hoping someone may be able to offer some advice regarding an unusual issue I’m experiencing with several Dorgard door retainers installed in a hospital building.
For anyone unfamiliar with how they work, Dorgards are battery-operated devices that hold fire doors open. They have a built-in microphone that detects the sound of the fire alarm and, upon activation, releases the door, allowing it to close.
Generally, they work very well, and I’ve had no major issues with them.
However, I’ve noticed a strange problem. When installing a brand-new Dorgard, the two C-cell batteries typically last a considerable amount of time. Once the original batteries eventually go flat and I replace them, the replacement batteries seem to last no longer than six weeks before needing to be changed again.
This has happened on multiple units, and I’m struggling to understand why the battery life appears to deteriorate so significantly after the initial set.
Has anyone experienced anything similar or have any suggestions as to what might be causing this? Could it be a fault with the units, increased power consumption, or something else I’m overlooking?
Any advice or suggestions would be greatly appreciated.
Many thanks in advance.
Rubbish /fake batteries….where did you get the batteries from ? What make ? Try a set of these from toolstation
We used to have them at a voluntary organisation I am involved with, and I think we had a 12-month renewal schedule. Yours look like a different model, we just had the foot button on top.
Don't recall tbe batteries, but probably the "industrial " Duracell.
There's a thread about catflap batteries - upshot was that you have to use the very best batteries, because "fairly good" ones last 2 weeks.
Amazon sent me an email to say Duracell batteries I had bought from them were fake. Compared next to the real thing they were very good copies on the outside, but clearly not the same inside.
Screwfix had some good deals on big-brand batteries last week.
I stocked up.
40 Varta for less than the price of 24. Or 20 Duracell.
Noisy areas will flatten batteries faster.
They should beep when batteries start to die but they don't always. Often they just die which points to the battery connection problems, as I've found just removing batteries and putting back fixes them.
Always test batteries before replacing as this points to a faulty unit.
For the money they are poor build quality and don't last as you say. Jmo.
We have doorguards in my old workpace. (A university art department)
The students used to wedge fire doors open all the time, as they used (noisy) trolleys to move stuff around, and carried huge paintings/art around
So we fitted the door guards, which do go off sometimes when a noisy trolly runs on the concrete floors.
We turned down the sensitivity, on recommendation/approval with our fire officer.
They still go off if the alarm goes off.
Don’t use rechargables.
