External Siren back up battery lifespan
18 Jan 2009
Merseyside
Hi everyone!
As the title suggests, how long should the battery back up in an external alarm siren last?
I installed the alarm system myself in 1999 and I've regularly changed the panel back up battery every 4 to 5 years, but the bell box battery has never been changed.
System is working well atm. Any advice would be appreciated!
Cheers.
20 Nov 2007
How do you know that the external bell is working correctly?
How did you test it?
ps Well done with the panel battery, spot on.
16 Feb 2011
Sheffield
Remove power to bell box at panel end .... 1 Does it ring ok outside ? 2 Sound like a chirping bird ? 3 No sound ?
If it sounds ok ...leave it
If not ....either don't worry about it or replace the whole bell box as the battery will cost half of a new bellbox
18 Jan 2009
Merseyside
Thanks chaps!
Europlex, the external siren triggers ok under alarm conditions, so I'm assuming it's ok?
sparkymarka, good shout. I'll give that a try when I'm next at the property.
The alarm system is fitted to our first house which we are renting out. Old tenant has moved out, new tenant moves in next week. Just getting some jobs done before they move in, one if them is testing the alarm system.
Thanks again.
29 May 2010
Nottinghamshire
Surely this will on prove that the battery will last for 2-3 seconds and not a minimum of 15 minutes.
Not much of a test imo. If the bell box cable gets cut the battery could only last a minute or so. Who knows.
20 Nov 2007
How do you think SAs are tested then? 3 alarm engs in the same street, all 3 SAs being left until the batteries run down?
steveo44 tell us please, how do you test them then?
By the way experience also goes a long way during the testing.
29 May 2010
Nottinghamshire
Can you please inform us on how to test the backup battery correctly or do you just blag it and hope for the best.
I suspect you have no idea how long the battery will actually last for just that it did work for the few seconds that you tested it.
29 May 2010
Nottinghamshire
Still waiting on this... :sneaky:
29 May 2010
Nottinghamshire
Think we are waiting for you answer "mr 3 thanks " or nobody really cares !
I have no answer! I am a Diy enthusiast. I am looking for an answer from a professional security installer or electrician like yourself. If you do not know how to test the backup battery then just say so.
I can only quote Socrates here:
“When the debate is lost, slander becomes the tool of the loser.”
16 Feb 2011
Sheffield
Yes I know ! with a battery tester ...just wondered if you knew or wanted to spend £170 tool to test such items ?
29 May 2010
Nottinghamshire
Make your mind up!
