- Joined
- 6 Aug 2017
- Messages
- 60
- Reaction score
- 0
- Country
Just looking for some advice on whether I’ve done the right thing. Our house (1950s build) had blown plaster which you could peel away with your hands. I knocked all this off and had the walls dot and dab boarded and skimmed. The ground floor is suspended wood floor with crawl space below. I have only done 3 rooms so far.
I am coming to realise that this may have not been the best approach and that I should have got the rooms wet plastered instead. I don’t any issues yet but I am concerned that the gap between the plasterboard and walls will act as a channel for cold air from mortar gaps and the crawl space below to surround the rooms and reduce the efficiency/ warmth of the house. Also concerned regarding mice etc finding their way into this space.
Our plasterer didn’t recommend wet plaster due to more issues with cracking. Likely it would have just taken him longer to do and higher cost?
So really the question is, am I thinking too much into this and this is now standard practice or am I likely to find issues. If so are there ways I can mediate things? I could get into the crawl space and inject expanding foam around the room perimeter to seal the base of the plasterboard?
Thanks,
Dan
Thanks,
Dan
