S
snadge
As some of you know I have to Dot&Dab the kitchen...
the reason as cos it is cover in thick pasty artex and also one half was covered in tiles and taking them off brought some of the finish plaster off revealing render underneath
now my plan was to remove all the loose stuff and put PVA on and get going but ive never Dry walled before so i thought I better check incase its the wrong thing to do... does all the render need to be chiseled off the block wall with spade end machine before hand or can i just go with my original plan?
see my photo below, u can see the render underneath where some of the plaster has come off - in one spot about 50 ml diameter you can see the block wall
thanks in advance
thanks in advance
