My builder has suggested using an appropriate UB on both the inner and outer course of blocks, and then boxing it in prior to rendering. There is a substantial gable over the garage (4.8m to ridge) however the roof is being built using attic trusses rather than purlins, so there will not be that much weight over the door. Both internal and external courses are concrete block.
I am not happy about the us of a UB, as I would like a row of vertical bricks over the door to tie in with the house.
Is it possible to use a Catnic type lintel? I've seen some listed, but them seem very expensive when compared to a UB.
Alternatively I've seen UBs with a metal plate welded to the bottom edge to take the outer course, but not sure whether this would be suitable for such a large gable.
Any ideas / suggestions would be appreciated.
Thanks.
Thanks.
