It's not my DIY disaster and I have a feeling that it was done by a company rather than an individual.. which makes it worse, i'm no professional double glazer but i'm pretty sure this isn't right.
ok before shot, they left the old wooden window frame in place and fixed the pvc frame onto it with brackets which then required some thing to cover it, they used pvc profile.
so when you take off the pvc profile it reveals bits of wood that they glued the profile onto and the brackets, plus a gap all the way around the frame.
it is covered on the outside with a thin sheet of some composite with zero percent insulation value and indeed I could quite often see daylight..
I had thought it was a little drafty
