Have purchased several Magnet wood windows, all pre finished with the intension of glazing myself.
I've got the units but am not 100% clear on the fitting.
I realise that there should be packers under each unit and they should fit centrally in the frame but what about the actual fitting.
Do I put sealant on the inside face of the glass?
Also, the bottom bead doesn't seem to sit properly when I fit dry, there is a 2/3 mm gap at the top and bottom of the side beading where they abut which goes when I push the bottom bead up, therefore , should this bead also be packed?
