    Dismiss Notice
Double light switch causes affects light in another room
Discussion in 'Electrics UK' started by salder, 21 Dec 2013.
  1. salder
    salder
    21 Dec 2013
    3
    Thanks Received:
    Kent
    Country:
    Have tried to replace double light switch (for separate hall and outside light - both singly operated). There are red, yellow and blue wires and a small piece of red which fell out when opening switch. Put red to L with small piece looping to other L and yellow and blue to separate L1's but this affects the light in the study (it flickers/stays on) Didn't take proper note of where the wires went before as assumed this was straightforward. Any advice gratefully received.
  2. Sponsored Links
  3. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,628
    Thanks Received:
    2,381
    Londonderry
    Country:
    Do the two lights function correctly off the switch?
    The flickering maybe down to a coincidental fault, rather than one being introduced.
    I would first investigate at the switch/switches of the flicker light for loose connections, then at the fitting.
    Just in case the replacement switch is looped in live to the flickering one, I would check that you have the termination tight and good contact of the copper ends.
  4. sparkwright
    sparkwright
    20 Aug 2009
    7,139
    Thanks Received:
    870
    Dorset
    Country:
    As above. It would seem you have wired the switch correctly.
    Have you replaced any other lights or switches recently?
  5. salder
    salder
    21 Dec 2013
    3
    Thanks Received:
    Kent
    Country:
    The switch does give power to both hall and outside light but more power seems to go to light in study(i.e. brighter). Have not replaced any other switches. Did try to put up new ceiling light in study (light that is coming on) - but reverted to original ceiling rose. With switch in hall disconnected light in study works normally.
  6. knowall
    knowall
    3 Sep 2013
    231
    Thanks Received:
    10
    Blackpool
    Country:
    If the light in the study "stays on" when you have the light in the hall connected and the study switch off you have two feeds!
    The external light does't have a pir, by chance ? What happens if you remove the link wire that dropped out when you removed the switch ?
    Regards,
    KA
  7. Sponsored Links
  8. sparkwright
    sparkwright
    20 Aug 2009
    7,139
    Thanks Received:
    870
    Dorset
    Country:
    You need to check this light, with the power off.
    Check all connections are sound.
    Note down exactly how it's connected, and report back.
    Be sure to tell us which WIRES are from which CABLE, so we know exactly how it is. Pictures would be even better.
  9. salder
    salder
    21 Dec 2013
    3
    Thanks Received:
    Kent
    Country:
    Thanks to everyone for their advice. Checked the ceiling rose and found it wired incorrectly. Neutral that was NOT switched live had red sleeve! Have now wired correctly and all lights working perfectly. Thanks again.
  10. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,628
    Thanks Received:
    2,381
    Londonderry
    Country:
    So that sounds like it was an historical problem, rather than anything to do with your switch replacement? (so original post/topic a little misleading in that regards!)
  11. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    [​IMG]
  12. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,628
    Thanks Received:
    2,381
    Londonderry
    Country:
    Ah! I missed that, so Topic was headed incorrectly then.
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
