Hello
can anyone help?
I have replaced a single switch with a double switch but I can't seem to get it to work.
I have installed an exterior light and ran some twin and earth back to the nearest light switch, which explains why I am replacing the single with the double.
In the original switch(part of a 2 way system as it is the landing light):
R - red wire
L1 - blue wire with red sleeve (seems to be the live)
L2 - yellow wire with red sleeve
In the new switch, I have replicated the wiring for the original light, but whatever way I try wiring the new light, the new light won't operate.
I have swapped the fittings, so can confirm that there is no error with the fitting. I also replaced the cabling today to make sure that there was no problem there.
can anyone help?
R - red wire
