AS long as it is a brass tail you should be able to tighten it up nicely it's the plastic ones that tend to strip if you need to nip up a bit.
Fibre washers tend to swell as they get wet the standard one should be fine.
The main thing is to ensure the pipes come together squarely even a slight angle will cause problems.
